The sensor is $25. I'm not sure how hard it is to change on the V6, but on the V8 it is a five minute job.
The harness could be expensive depending on how much is on that one harness.
A good independent shop would probably repair the harness instead of replacing it. The dealers always replace instead of repair.
They should be able to provide a written estimate with the parts and labor charges indicated. It would be interesting to see how that breaks out.
While wiring is not hard, it can be time-consuming, especially if replacing the harness means unwrapping it from another one. You might ask to see the parts that will be used, and if it's just a matter of unplugging one connector and plugging in another, take the job on yourself. If that's the case then it should just be a matter of starting at the sensor and unwinding the harness until you reach the other end. If it's a bunch of pigtails, it will involve unwrapping the harness far enough back to get to the wires, then cutting the old wiring in and installing the new. This means cut a wire, match it to the new harness, strip both wires back, slide heatshrink over one end, solder the two wires together, slide on the heatshrink, and heat. Being a crank sensor, we should only be talking about 2 wires here.
