stumpy
Gentlemen,
I'm back to the hate part of owning this car, and I want some good advice.
2004 v6, 144k on the scoreboard.
All fluids, including transmission was flushed back in 2011 when purchased by dealer around 120k. No clue if previous owner did a flush.
Zero tranny issues until yesterday.
Hard shift from first to second. Drops down from 3rd to 2nd and back to 3rd when accelerating to 55ish.
No issues with reverse shifting or park.
I'm having the exact same symptoms as these two guys have. Both did the work and spent the $$$ and they then found out it was PCM.
http://www.justanswer.com/ford-lincoln/6f4u0-lincoln-ls-2003-licoln-ls-v6-engine-5r55s-transmission-problem.html
http://www.searchautoparts.com/motorage/powertrain-pro/easing-harsh-engagements-lincoln-ls-5r55s
I'm split between changing the solenoids as everyone here tells me, or just getting a new PCM and knocking this out.
I reset the memory and it didn't make a positive difference.
Maybe related: The plugs, coils, and valve gaskets were done about 4000 miles ago. The cat is still weak and throwing a code from the bad burns, but the PCM seemed strong during the past 4000 miles.
