jmtsstewart
Hello,
Well, my honeymoon is over with my '01 v6 (107k) because after 3 weeks the trans died the day after i replaced the clockspring.
It has reverse and acts like it has drive (although delayed), until i give it gas and then it seems like it just goes into neutral. It doesn't matter which drive gear it is in, and i just tried to replace the solenoid block and that didn't fix it. It may be a problem within the valve body, but i don't have the resources to work through that quickly enough.
So, can i use a v8 5r55n trans in my car? I've found a couple of those but none out of a v6 yet.
Thanks, jason
Thanks, jason
