For Sale $500 Parts LS, only 120K On V-8
Cars For Sale Forum
  1. Turboguy
    Turboguy Well-Known LVC Member
    220
    3
    Nov 22, 2010
    Western Nebraska
    Contact Seller
    120K 2001 3.9 V-8, synthetic only, have maintenance records
    New windshield from last year, old one got broken in hailstorm
    4 newer tires with lots of tread, on factory 16 inch rims
    Lots of newer mechanical parts, body hailed out
    Alpine deck / 4 Infinity 6x9s / Kicker sub amp, worth $500
    The straw that broke my back today was the top starter bolt.
    Two weeks ago, I drove it though our muddy dirt road and it ran fine until I turned it off, but now only getting clicking when try to start it, lights still fine but I think starter quit.
    Tried to swap starter today, but officially tired of working on it and spending $ on it. So if you’re needing parts for a project, you’re going to get a hell of a deal.
    Was a salvage car that was considered totaled at 96K miles, in 2007 in Indiana. The previous owner said he was told someone hydro locked original engine around 95K miles, then a 2001 engine was put in. I bought it in 2010 in Tampa with 128K miles on it.
    Estimate 120,000 on engine now, I’ve only used synthetic Mobil 1 on it since then, and had an LS specialist from this board do a ton of work on it in 2012 including checking timing chain guides which were in good shape then, and there’s no audible chain noise now.
    See attached maintenance records.
    I’m 30 minutes north of I-80 in western Nebraska, bring a trailer.
    MAINTENANCE NOTES:
    2000 Lincoln LS
    VIN:1LNHM87A9YY755743
    November 2016 Service: Blake’s Auto, Oshkosh NE
    2 rear rotors, Bosch
    2 sets of rear pads, Bosch ceramic
    2 rear steering links replaced with new nylon nuts, Motorcraft
    SPRING 2016 SERVICE: Blake’s Auto
    Replaced:
    2 front rotors, BRRF222 Motorcraft $122 for both
    2 sets of front pads, BR1273 Motorcraft $31 for both front wheels
    2 front wheel hubs, Timken HA590213 or Motorcraft HUB20 $240 for both
    1 front upper left control arm with bushings and ball joints, 45D1268 AC Delco $122
    1 front upper right control arm with bushings and ball joints, 45D1255 AC Delco $122
    6/9/18
    OIL CHANGE
    6.5 Quarts Mobil 1 0-20 Advanced Fuel Economy
    Motorcraft FL2021 Oil Filter
    164,250 miles
    1/15/17
    OIL CHANGE
    161,600 miles
    Lubed lower front suspension with grease
    11/21/15
    OIL CHANGE
    156,335 miles
    Zip-tied trans or oil cooler lines up near pass side nose
    Lubed suspension with spray (couldn’t get to zerks on lower b joints)
    12/12/14
    OIL CHANGE
    NAPA Gold 1228 filter (Wix-made)
    150,400 miles
    3/26/14
    OIL CHANGE
    6.5 Quarts Mobil 1 5-30
    FL-2021 filter
    143,000 miles
    YW4Z-5421819-AA: inside front door handle-left
    XW4Z17603GA: wiper washer nozzles
    1/10/13
    Intake manifold blew out in the back, Nick replaced it with a used OEM manifold.
    Nick did suspension rebuild:
    Inner and outer tie rod ends
    Lower ball joints
    11/25/12
    HEADLIGHT BULB UPGRADES/ANGEL EYES
    Phillips HIR2 9012 - 55 watts - 1870 lumens (low beam)
    Phillips HIR 9011 - 65 watts - 2350 lumens (hi beam)
    Mod to fit 9012 bulbs: Philips HIR2 9012 Standard Halogen Headlight Bulb
    5/1/2012 SERVICE: 135,700 MILES
    Car to: Nick, New Rochelle NY
    $260 non-Ford parts, $1,340 Ford parts, $675 labor = $2,275
    Codes: P0430: Catalyst Low Efficiency Bank 2 (Cat converter bad) (driver side rear O2 sensor) Code P1565: Speed Control Command Switch Out Of Range High (Clockspring)
    Power steering pump squealing
    Oil changed: Mobil 1 6.5 quarts 5W30, Motorcraft filter
    Cleaned MAF sensor elements
    Installed K&N air filter 33-2266 in place of stock filter
    Installed new fuel filter in front fender location
    Replaced coils with (8) new Visteon coils 60-1008
    Replaced spark plugs with (8) new correctly gapped SP-467 Platinum plugs
    Replaced old gaskets with XW4Z6584AB and BB Valve Cover Gaskets
    Replaced old O2 sensors with (2) Motorcraft 9F472 AA (upstream) O2 sensors
    Replaced old O2 sensors with (2) Motorcraft 9G444BA (downstream) O2 sensors
    Replaced broken clockspring with (1) Clockspring P/N XW4Z-14A664-AA
    Replaced front rotors with (2) XW4Z1125 AA front rotors
    Replaced front pads with (2) 6W4Z2001 BA front pads
    Replaced rear rotors with (2) Rear Rotors
    Replaced rear pads with (2) Rear Pads (WILL YOU BLEED BRAKES AFTER?)
    Replaced front shocks with (2) Base Front Shocks: 1W4Z 18124-BA
    Replaced rear shocks with (2) Base Rear Shocks: XW4Z 18125-AA
    Replaced end links with new stock end links
    All fluids checked
    Serpentine belt checked for cracks/life left
    Wheel hubs/bearings checked for play
    Ball Joints checked
    Tie Rods checked
    General suspension (sway bar bushings/end links) checked
    Suspension squeaking over bumps: if new shocks won’t fix, lube/check suspension
    Hard reset oil change/AC filter messages (AC filter fairly new)
    If applicable, make sure steering wheel is straight after clockspring work
    NOTES
    New clockspring, but airbag light is still on, and radio display is still not working
    Hood alignment still off
    Some of my lug nuts were bad, Nick replaced with better ones
    Lower ball joints on both sides are bad, so is a tie rod end.
    9/1/11 SERVICE:
    OEM Replacement Walbro Kit: www.fuel-pumps.net/tca919.html
    Walbro TCA919 OE Replacement Fuel Pump Kit, Item Code: TCA919, $124
    Fuel pump replaced w/Walbro unit & new fuel socks, factory in-tank fuel filter removed. Sender ground wire from old in-tank fuel filter put onto fuel pump housing screw.
    Replaced Fuel pump fuses that blew.
    Replaced cabin air filter
  2. Turboguy
    220
    3
    Nov 22, 2010
    Western Nebraska
    Now $300, keeping the alpine deck.
  3. Turboguy
    220
    3
    Nov 22, 2010
    Western Nebraska
    Sold
Share This Page
