ZacUnknown69
Firstly - I'll get the current things out the way. My front bags have been inflated as much as the system will let them and won't go back down. So is there a way to manually release the air? I plan to get it to my desired height and just turn it off during winter.
Secondly - I've began to hear a creak, at first I thought it was a bushing. But it got worse and louder so I took it in to have an evaluation and 'they' said it was the upper and lower ball joints. But the estimate cost was $400 to replace it. Though I can buy it all myself for under $100 and do it alone (much like my love life). But I got confused because there's so many different ball joints - upper, lower, control arm, etc. What can I do?
Third - I bought some Innovite HID Bi-xenon headlights. They're both high and low beam in one bulb. Since the Mark has 2 different connectors for which beam - will that cause a problem and allow me to only get one beam? Are they on the..same circuit and get the hint? Or will I have to buy another - as in one HID assembly for low beam, and another for high beam?
Lastly - Here's the fun one, within a year I'll be getting a very handsome sum of money. In which I'll be putting into my car, investments, and giving some to my parents. But we'll focus on the engine - I can't decide on what to get between a supercharger, twin turbo, or a Procharger. I want to keep the displacement of 281ci, 4.6L, the same. But really I basically just want it to bolt right in. What engine will be a direct swap?
If you're reading this - you've done it. It seems like this site is dying out and I don't really expect a whole lot of attention from this post. So if you stuck with it; thank you for reading!
