2nd attempt to repair air ride
Lincoln Mark VIII
  1. BILLBOATS
    BILLBOATS Well-Known LVC Member
    488
    17
    Sep 29, 2014
    Akron
    My 96 mk 8 had been sitting on its from in my drive for near 2 years . Last year I bought all new arnott air parts intending to rebuild the air ride. However I could not find A WAY TO LIFT UP THE CAR ENOUGH INCHES TO GET A 3 INCH jACK FOR A START TO RAISE IT UP. ONE OF THE GUYS HERE SAID TRY A 2"X3" BOARD . THAT SOUNDED promising as the end of the board can be tapered allowing me to drive the rear wheels up onto the board. Plan to have same in front of the front wheels . Provided I get it up my next question is. What steps are necessary to reach the air compressor. The front bumper has to come off to reach the rt front corner of the MK 8 thus allowing axcess to the compressor. The compressor will not run with the key in on position. I have a super star 2 tester. Suggestions appreciated expecially disassembly of the front bumper cover and removing the compressor.
  2. Scallywag
    Scallywag Well-Known LVC Member
    202
    7
    Oct 4, 2010
    Franklin Park
    Do you have the scissor jack that came with the Mark? That thing goes pretty low.
    Although a low profile jack should be able to get underneath, you can do as you say was already suggested and wedge a board in front of the right front tire, drive onto it to elevate it enough to slide the scissor jack underneath, jack it enough to use your regular jack, and then continue on from there.
    As for the air-compressor; I suppose you can access it through the bumper, though ideally you'd want to get at it through the passenger side wheel and removing it is pretty straight forward. I've uploaded the removal process from the 98 workshop manual as the 96 doesn't have images for some reason.
    Since you have the Super Star 2 Tester, then;
    1. Enter function test to vent suspect air spring solenoid/s.
      • Test 213-LH Front.
      • Test 215-RH Front.
      • Test 217-LH Rear.
      • Test 219-RH Rear.
    Here's a video where the Rotunda tool is used at around the 2:40 mark(no pun intended. or was it?) to adjust air ride height.
  3. BILLBOATS
    488
    17
    Sep 29, 2014
    Akron
    I see you live in the Akron Area according to google map. Thanks as your suggestions are helpful. Until the temp gets steadily above 50 , likely in April, I am prepairing tools and ways to get the car up and off the ground. I have not as yet used the super star so I'll need some coaching when the weather gets better. Last year I bought 650.00 of air stuff from Arnott but realized I could not get the car up . I sent it all back and had a good business relationship with the company. I'll buy from them again
  4. Scallywag
    202
    7
    Oct 4, 2010
    Franklin Park
    If you haven't used the Star II tool, then you may want to grab this PDF from the 96 Workshop Manual that I uploaded.
    It explains how to use the Rotunda New Generation Star(NGS) or Super Star II Tester for Diagnostics/Functional Testing, so be sure to pay attention to the instructions that pertains to your particular tool for setting it up.
  5. Dabaholic
    Dabaholic New LVC Member
    3
    Mar 20, 2019
    Flagstaff
    I went onto the arnott website and it only showed the rear air springs, i cant find fronts anywhere online, can anyone suggest somewhere?
  6. dgaddie
    dgaddie New LVC Member
    Jan 5, 2012
    Wellington
    There are several places online to buy the fronts. You might not want to buy them until you find the problem. my experience with this is when you have all four corners down, you have a check valve problem. Inside the compressor.
  7. xtriggerman
    xtriggerman LVC Member
    33
    17
    Jan 7, 2019
    TN
    If they are original to the car, they more than likely have or will shortly have dry rot cracks in them. If I wanted to keep bags, I would clean slate the car with new bags and then track down each and every other issue. After a lot of reading, I convinced my self to go springs on my 97 and am very happy with the ride quality.
  8. Dabaholic
    3
    Mar 20, 2019
    Flagstaff
    Ok what the best conversion kit to buy?
  9. xtriggerman
    33
    17
    Jan 7, 2019
    TN
    Monroe is what most every one puts up front and Arnott are suppose to be good. The Monroes sell each singularly for free shipping here since it costs less to the seller. Make sure they are a left and right 90002-1 & a 90002-2 Like these.
    Air Spring to Coil Spring Conversion Kit Front Left fits 93-98 Lincoln Mark VIII | eBay
    Air Spring to Coil Spring Conversion Kit MONROE fits 93-98 Lincoln Mark VIII | eBay
    For the rear, you could stick with the Monroes like this set
    Air Spring to Coil Spring Conversion Kit Rear fits 93-98 Lincoln Mark VIII | eBay
    Or there are cheaper but make sure the springs have close to closed loops on the ends. The wide open last spring loop is not a good idea.
    Also be ready to put in new upper control arms up front. When these bags go flat up front, that usually wipes out the old rubber bushings in the control arms if they didn't go bad all ready. Personaly, I would get ones from Rock auto with grease fittings and go there for grease fitting-ed ball joints if need be also.
  10. BILLBOATS
    488
    17
    Sep 29, 2014
    Akron
    First of all thanks for all the instructions to help find whats keeping the car"s frame smack dab on the driveway gravel. Making a set of ramps to lift it 2 inches would help get a jack of some sort underneath the frame and allow more lifting till there is room enough to pull off the front bumper cover and axcess the compressor. I thank you for the directions to use my super star 2 . I'll try this before going to the labor of ramps and compressor removal. I do not post a lot and infrequently look up replies. So appreciate a workable answer and welcome any other workable ones too. Let you know of progress made in the next 4 weeks or less
  11. BILLBOATS
    488
    17
    Sep 29, 2014
    Akron
    The fronts are just struts with built in air bag around each strut. They are not like the rear bag
  12. BILLBOATS
    488
    17
    Sep 29, 2014
    Akron
    I just ran all 8 pages on my printer so when the opportunity comes I can have them next to my mark. I have a desk to so it can't be moved to the car like a lap top. Thanks
  13. BILLBOATS
    488
    17
    Sep 29, 2014
    Akron
    Its been a while since I last spoke to you and others about this problem. We had a cold March and april bings showers although they bring May flowers they don't help mark followers fix their cars. I have to wait till a streak of warmth come along. Meantime build those ramps. If I can get the right front up I could remove the tire but how hard is it to remove the inner fender wheel well?
  14. Scallywag
    202
    7
    Oct 4, 2010
    Franklin Park
    If anything, you can also download the Adobe Reader app to your phone and glance at it everytime that you need the information rather than to take the print-out. Though, the font size on the print-out will probably be more convenient than the phone's font.
    As for the wheel well,...
    If you mean removing the shroud/splash shield inside the wheel well, then it's pretty straightforward. You merely remove the fasteners & pushpins as shown in the first upload, "98 Air Ride Compressor", and then finagle the splash shield from the lip it's inserted into.
Share This Page
