2012 Lamborghini LP700 Aventador
LaserSVT
Waco
Lamborghini’s next hypercar has made its world debut at the geneva motor show, and dare we say what a hypercar it is! The new bull god will feature an earth shattering 700hp v12 and the highest power to weight ratio of any car in its class. Yes, this is the new, long waited lamborghini aventador lp700-4.
Lamborghini is really good at creating sinister super sports cars, but it is equally as talented at naming them. According to the company, "aventador" was the name of a bull that entered into battle on october 1993 at the saragossa arena, earning the "trofeo de la peña la madroñera" for its outstanding courage. Having the courage to go up against a new world of super sports cars will be the name of the game for the new lamborghini flagship. Today’s world is extremely high-tech and many new players have entered the arena. Lamborghini has been promoting its carbon-fiber monocoque technology and the aventador’s 2.9 second 0-62mph, but will that be enough?
According to stephan winkelmann, president and ceo of automobili lamborghini. "the aventador is a jump of two generations in terms of design and technology, it’s the result of an entirely new project, but at the same time it’s a direct and consistent continuation of lamborghini’s brand values. It is extreme in its design and its performance, uncompromising in its standards and technology, and unmistakably italian in its style and perfection. Overall, the dynamics and technical excellence of the aventador lp 700-4 makes it unrivalled in the worldwide super sports car arena."
Lamborghini has made it clear that a V12 engine will be the only thing to ever power their supercar, but it was time to develop a new and modern version of the legendary V12 of yesteryear. The Aventador will come with a new 6.5-liter V12 engine with an AWD layout that produces 700 HP 8,250 rpm and 509 lb-ft at 5,500 rpm. It is the first all-new Lamborghini developed engine since the Countach. This engine will be able to get from 0-60 mph in just 2.9 seconds while blasting off a top speed of 217 mph. With a total weight of 1,575 kilograms (3,472 lb) it will deliver a power to weight ratio of 2.25 Kg/hp. These figures are astounding, but not out of this world. Lamborghini has surely created a super car, but until we can get it on a track with its competition we will not know if the Bull can reign King.
Design of the engine was simple in theory. The car needed a powerplant that was lighter than the old one and more powerful. That tends to be the problem with just about every iteration of a new sports car, but Lamborghini was able to develop several new ways of solving it. They made the engine lighter by using an aluminum-silicon alloy to lower the overall weight to just 235kg. Parts that are more readily exposed to high heat were still forged from steel, but the overall engine weight is equal to 3.0hp per kilogram.
The Aventador’s engine is mated to an all-new “Lamborghini ISR” – the ISR stands for Independent Shifting Rod - seven-speed single clutch automated manual gearbox that combines quick shift time with manual shifting, which proves to be quite useful when a car has a low weight and compact dimensions.
The ISR gearbox allows the Aventador to shift gears almost simultaneously. It comes with two modes and 50 millisecond shifts that works in such fashion that when one of the shifting rods is moving out of one gear, the second rod is already shifting on to the next. Another important aspect of the new Lamborghini transmission fits perfectly with the company’s new goal of making its supercars more lightweight: the ISR transmission weighs in at only 79 kilos – about 174 pounds – significantly lighter than any other DSG transmission out on the market.
the new Lamborghini powertrain is a revolutionary new technology that will set apart the Aventador – and all its future models - from its supercar contemporaries.
Lamborghini president and CEO Stephan Winkelmann explains that the new Lamborghini powertrain is a revolutionary new technology that will set apart the Aventador – and all its future models - from it’s supercar contemporaries. “This new power unit is not only the crowning glory of our product range, it is also part of our enormous investment in the future of the Lamborghini brand,” he said.
The Aventador’s monocoque will also be made solely of carbon fiber. When using this lightweight material it is possible to create structures that are much stronger than steel and also many times lighter. Until recently this material was used very little and few companies had the technology to create entire tubs out of it. Ferrari was one of the first manufacturers to take its carbon-fiber technology from the racetrack and incorporate it into the Ferrari F50 road car which had an entirely carbon-fiber tub. The newest one, designed by Lamborghini, puts the entire shell of the car from roof to floor in one component. Overall the part of the car where you will be sitting while hurtling over 200mph will only weigh 325.18lbs.
The body and chassis will be entirely constructed from carbon fiber. In collaboration with Boeing Corp. and the University of Washington, The tub and body that boasts stiffness calculated as 35,000 Newton-meters per degree of deflection. By comparison of stiffness, the Koenigsegg CCR is 28,100 Nm, the Ferrari F50 is 34,600 Nm, and the existing Murcielago is 20,000 Nm.
"Systematic lightweight engineering and an optimum power-to-weight ratio are absolutely crucial to the super sports cars of the future, for both the highest levels of driving pleasure and lower emissions," says Stephan Winkelmann, President and CEO of Automobili Lamborghini. "Lamborghini has put a lot of hard work into growing its expertise in the application of CFRP, attaining the leadership position we hold today. With its innovative carbon-fiber monocoque, the successor to the Murciélago displays the full competence of our brand and starts a new chapter in the history of Lamborghini."
It is clear to see that Lamborghini engineers and designers truly started from scratch when creating the Aventador. This car will have an entirely new suspension concept that comes straight from Formula 1 racing. It will also utilize a more typical double-wishbone setup and a supercar standard carbon-ceramic brake system. Also at the front axle are shock absorbers that come equipped with a hydraulic lifting system enabling the front end of the super sports car to be lifted by 40 millimeters at the touch of a button. When driving a Lamborghini through any parking lot with speed-bumps you will immediately recognize the convenience and need for a system that lifts the front end.
A new and innovative steering wheel system will also make it into the Aventador. The system has the ability to think its way through a bend adhering to the perfect line. This could be similar to the McLaren MP 4-12C brake steer system that will debut this month. It, in conjunction with a dozen computer systems, analyzes how the driver has entered a curve and adjusts steering inputs and braking to help the car maintain a more efficient line.
Next to the impressive 700 HP V12 engine, the new supercar will also feature an innovative and highly sophisticated suspension concept. The first details of the concept reveal that the pushrod spring and damper was inspired by Formula 1 and adapted to a high-performance road-going vehicle, allowing it to handle better and be much more responsive. Next to this, the Aventador will also get an aluminum double wishbone suspension and a carbon ceramic brake system. The spring elements are not located on the wheel mounts, but connected inboard to the bodyshell structure. They are transversely positioned: under the windscreen in the front and close to the engine in the rear. Also at the front axle are shock absorbers that come equipped with a hydraulic lifting system enabling the front end of the super sports car to be lifted by 40 millimeters at the touch of a button. When driving a Lamborghini through any parking lot with speed-bumps you will immediately recognize the convenience and need for a system that lifts the front end.
The new Lamborghini Aventador LP700-4 will go on sale in late summer 2011 at a price of $379,700. Don’t expect to see many of these exotic beauties at the nearest dealership. Lamborghini has been taking orders for years and will have to fill those sales requests before one just sits on a dealer’s lot. In total, only 4000 units of the supercar will be produced, which is 99 units less than the Murcielago. If any more than that were produced, the Aventador would not be profitable. According to Autocar, "the carbon fiber molds that are used to construct the car’s monocoque can be used as many as 500 times before they have to be replaced." The Aventador’s price is equivalent to eight sets of monocoque molds.
If you are truly in the market for one, there are far too many bespoke options to choose from – we would certainly want to go through the design process ourselves and order one from the factory in Italy.
If and when the Lamborghini Aventador is released – teaser images have pointed to a 2012 launch date – it’s a pretty safe bet that it’s going to go head-to-head with a number of other new exotics, with the most notable of which being the Ferrari 599 GTO. Numbers aren’t too far from each other with the Aventador’s 700 horsepower, 2.9-second 0-60 mph time, and 217 mph top speed going up against the 599 GTO’s 670 horsepower, 3.3-second 0-60 mph time, and 208 mph top speed time.
With the specs of these two Italian thoroughbreds closely similar to each other, it should make for a nice comparison test between the two. Sure, we’re going to have to wait until Lamborghini officially introduces the Aventador for that to happen, but we’re pretty confident that at some point, it’s going to.
Lamborghinis and Ferraris will always be interlinked with each other so bragging rights between the 599 GTO and the soon-to-be-released Aventador LP700-4 should still make for a very interesting comparison test. Other companies will be having there chance to take a shot at this raging bull including Pagani and McLaren. Many people know little about these companies, but they produce some of the baddest sports cars on the planet. Their most recent models have pushed the limits of engineering and manufacturing and the newest models will be more than light competition for the Lamborghini. The McLaren already promises similar performance from a smaller and more economical twin-turbo V8 engine. The Pagani will be utilizing an AMG V12 like the past models and have a peak output close to the new Lamborghini. In a perfect world, we would love to see these four new cars on one track at the same time to duel it out for bragging rights.
And yet you refuse to believe that an LS looks like a Galant.
:lol:
I was in my Mark the other day and a WOO WOO pipe car flew by,I said,what moron put one of those on a LS. Turns out,it was a Galant.
BTW,the hood on that Lambo looks killer.
