2006 LS V8 Power Steering Leak
StaySideways
Pinckney, Michigan
I am losing power steering fluid, fairly slowly, but it looks like it is coming from an electrical connector, I have attached a picture below. After trying to search the forum for a good post, best I have come up with is that it is probably a power steering pressure switch. What is the part number and the procedure for changing it.
Leaking from the electrical gizmo is well known. Someone will chime in soon with the part number---I don't have it handy.
KS
There are a few on here that have replaced that switch. So far, I'm not one of them. Originally, Ford insisted that the entire hose /w pressure switch be replaced, but they've backed off on that. AFAIK, it just unscrews (open end wrench at the base of the switch).
I think I read on here that some are located on the power steering pump and some on a PS hose. Which engines/models have it located where?
i don't know. 2006 lists only the one on the hose, other years list both.
