AmsterDutch
2004 LINCOLN LS V8 OEM ~ FUEL VAPOR CANISTER PURGE VALVE ~ PART # 3W43-9G683-AD | eBay
I just bought this early this morning ...still chasi g a P0455 code ...CEL came back on this weekend ... thought the new gas cap fixed it but I guess not ...I wouldn't have bought the fuel vapor canister purge valve but I needed the hose that is connected to it ...the hose connected to the valve is a discontinued part so I'm very happy to have found this on ebay ...now to my question ...I tried using my ohm/volt meter to test the voltage for the valve connector...should this connector be pushing out 12-Volts? When I test it the highest reading I was able to get was 09.0 on the 200 Volt setting...can someone please explain/teach me what module is controlling this Valve? Thanks
