2006 Lincoln Navigator Front End
  • Thread starter Thread starter Stillengle
  • Start date Start date
Could you be specific as to what you are wanting to convert? The 2005-2006 front end is the same as the 2003-2004 the only difference is the bumber and fog lights. You cannot convert the 98-02 body to the second gen. Hope this helps.
Sorry i was talking about the 03-04 Version of the Navigator Putting a 05-06 Front End on isnt the grill and headlights different also.
I am pretty sure you can buy the 05/06 front bumber and fogs to do the conversion. The grille and headlights are the same. Navi's had HID and non-HID headlights from 2003-2006. The only differance in the grille on aregular Navi is the teeth were more of a bright grey on the 2005-2006's and the teeth were a bit darker on the 2003-2004's. Unless you are talking the black, cashmire tri-coat or silver birch monotone editions in which case you are talking quite a bit of money to get everything switched monotone.
