2006 Lincoln LS V8 C2777 code?
Lincoln LS
  1. AmsterDutch
    AmsterDutch Dedicated LVC Member
    1,033
    169
    Jul 9, 2017
    Midwest
    Hey guys I searched the forum and found little to no info on this code and to make matters worse the car was a Gen 1 2002 LS ...Just wondering if I need to reprogram the ABS Module or Buy a new ABS Module and have the Dealership program it? C2777 - Sensor Cluster Bus Failure. I read somewhere that I might need to get the ABS module reflashed? Could I use Forscan to recalibrate this? I’m also wondering if this is effecting my speedometer? The Speedometer doesn’t work upon initial start up ...I shut the car off and turn it back on then it works fine? I also have a a left rear wheel speed sensor Code ...could it all be tied to faulty wheel speed sensor? Fingers crossed
  2. joegr
    joegr Dedicated LVC Member
    18,881
    1,255
    Dec 10, 2005
    Gulfport
    The speedometer issue is more likely to be related to the rear wheel speed sensor issue than the yaw sensor issue.
    Trouble shooting for the C777 code: 2006 Lincoln LS Workshop Manual
    It looks like there is no need to guess at it.
    • Like Like x 1
    • AmsterDutch
      1,033
      169
      Jul 9, 2017
      Midwest
      Okay I disconnected the Left rear Wheel Speed Sensor yesterday after replacing the serpentine belt ( Boy not much room to work on that little guy ...FOR ANYONE READING THIS PLEASE NOTE: it works best to work from bottom and top when replacing serpentine belt ) I then cleaned up connector pins and used a dab of Dielectric grease ...AT code went away and ABS code was gone ...upon driving to store I saw the speedometer wasn't working still so I proceeded to pull over and turn off car and restart it so the Speedometer would work because that was the quick fix all last week ...upon starting car again and driving it a half mile or so ....the ABS and AT light was still gone and the speedometer wasn't working and I kept driving ....all of a sudden the AT and ABS both came on with the sounding of alarm which dinged once ....then the speedometer worked...I guess I will have to dive deeper..... so.... my question is.... Where is the sensor cluster and ABS module in this 2006 LS located? I need to check for a short but never dealt with the YAW sensor cluster wires and ABS module before ( Never had these problems with my 2 1st Gens THANK GOD lol ) any help with locating these connectors would be greatly appreciated
    • joegr
      18,881
      1,255
      Dec 10, 2005
      Gulfport
      ABS module - front right under the hood, can't possibly miss it.
      Yaw sensor, under the floor console.
    • AmsterDutch
      1,033
      169
      Jul 9, 2017
      Midwest
      Thank you Joe
    • AmsterDutch
      1,033
      169
      Jul 9, 2017
      Midwest
      Not sure if I tested the right connector ...but I disconnected the blue connector and the green connector and reconnected them three or four times ...started the car and my Speedometer is working and the ABS and AT lights are off ...still need to research this more on the 2006 workshop manual...I'm hoping it was as easy as a bad connection but I'm not going to hold my breath
    • AmsterDutch
      1,033
      169
      Jul 9, 2017
      Midwest
      I just took the Car out for a quick test drive once again to see if the ABS and AT lights would pop up....No lights ....the speedometer is working properly ...before I tested the car I researched the Shop Manual and it actually said disconnect ALL THE INSTRUMENT CLUSTER CONNECTORS ...funny thing is ....I did this before I even read the Manual ...but really happy the manual said this was the proper procedure...
      Pinpoint Test F: The Odometer Is Inoperative
      Normal Operation
      Vehicle odometer information is sent to the instrument cluster from the anti-lock brake system (ABS) module over the communication network. Diagnostic trouble code (DTC) U1123
      F2 CHECK FOR CORRECT INSTRUMENT CLUSTER OPERATION
      • Disconnect all the instrument cluster connectors.
      • Check for:
        • corrosion
        • pushed-out pins
      • Connect all the instrument cluster connectors and make sure they seat correctly.
      • Operate the system and verify the concern is still present.
      So Anywho I’ll update if the codes come back ...the Wheel speed sensor code is gone also...I’m hoping for the best
    Share This Page
