I have been trying to bleed my 2006 Lincoln after having replaced the thermostat and all the plastic housings that go with it. When you press on the gas it sounds like an old 4 barrel carb. kicking into over drive and now the fan runs most of the time when it didn't. Gauge never shows over middle but when I pushed it a little the other day during its growling phase it started to overheat. Is this because I have air in the system? Also loses a lot of power when it does this but the air does not turn off. NOW for the big problem. While bleeding the system last night I dropped the screw that goes in the bleed port and it disappeared into the black hole that is a Lincoln engine compartment and no where have I been able to find one on line with out buying a full reservoir set up and I don't need that plus I don't want to pay 180 dollars for a plastic screw. Anyone with any idea? help is appreciated
