Southern Gramps
Short version: car stalled while driving (sitting at light) would not restart.
Trouble shooting. Fuses check good. I hear fuel pump run for two seconds when ignition is turned to run. Unplugged MAF and engine did start, running for a few seconds. Removed battery, charged, re-installed: gauges sweep - cranks no start. Unplugged MAF a second time - no start, gauges no longer sweep.
Possibly related: the fuel display currently and intermittently shows empty despite having a half tank of gas.
Long version: fuel display has been intermittent for months. Annoying but no impact to drive-ability.
Just prior to the above event, the car ran poorly. I parked it overnight, added two gallons of gas, car ran fine (including fuel level display). I took several short trips without complaint, then the above event happened. I have verified good fuses for: #5;fuel injectors, #12 COP, #17 fuel pump. Inertia switch is normal. I inspected the pins at the fuel tank connectors, good - no apparent issue. Engine light never came on. I do not expect to find any codes.
Help please!
Help please!
