1jerodjones
So I have an ac problem with my 2005 lincoln ls. I run the self diagnoses for the heater and ac and the code is 12 65 is that a code to replace the Blend Door Actuator? Thanks Jerod
THe ac isn't working. When I noticed I looked at the low side pressure and it was way high so I professionally removed refrigerant and refilled to proper level and it just seems like the ac isn't turning on.
B1265 is a false code on the 2003-2005 LS. (It would be false on the 2006 too, except they finally updated the firmware to not give that code.)I get nothing but hot air no matter what settings I choose. B1265 code.
2005 LS 3.0 v6
For sure!I replaced dccv. Maybe I should have bought OEM.
