JamesHinson
Have 2004 LS, v6.
A/C started blowing out hot air. Not constantly, would blow cold, drive for 30-60 minutes and might start blowing out hot air.
Repair shop replaced DCCV. Seemed to work okay for couple of days and then started same problem again. Went back to shop and they started talking about pull out dash to get to blend doors. I am NOT a mechanic, but had researched enough to know the car does not have blend doors.
Took to Ford/Lincoln dealer. They could not get it to blow out hot air for two days, said they had let it run for over 2 hours. Picked up car and in less than 2 miles, hot air. They say the DATC needs to be replaced, but they can't do because part no longer available.
When hot air blows out it is coming from all vents, though passenger side does not seem as hot as drivers side. Have run diagnostic on datc and do not get any codes.
Any ideas or suggestions would be appreciated, thanks.
