Interested what you would ballpark the value of this 2004 LS V8 ultimate sport at these days in this used car market?
Very clean with the following exceptions:
1) Thermostat needs replaced
2) Hard shift in lower gear (1 to 2), the 5r55s transmission total rebuild/upgrade was applied in 2017 but got hard shifts in low gears in late 2019.
166k miles, 69k of them between 2016 and 2021 under my ownership. I'm the third owner.
Noteworthy part replacements, etc:
Brand new snow tires on rear ( less than 500 miles on them)
Decent tires on front (50k miles with medium tread wear)
Always used Merc V for transmission fluid changes, always used full synthetic for motor oil.
All brand new/relatively new (less then 40k mi) suspension components front and back (new front struts, new front coils, rear sway bar links less than 40k mi, lateral toe adjust on rear less than 40k mi, wheel hubs / bearings on front less than 30k mi on them)
Brand new alternator with less than 500 mi on it
Brand new window motor and regulator on driver side front door.
Brakes and rotors in good shape.
NGK Irridium IX installed in 2016 with 60k mi on them
