2004 Aviator Keyless Entry
John_971
Plymouth Meeting
I purchased a 2004 Aviator, I do not have the code for the keyless pad on the driver's side door. I do remember reading a post saying that the master code is located under the driver side dash on a white sticker. I have looked, and found nothing. Are there any other areas I should look?
Thanks for any help! :)
I had the same problem on my 04'
couldn't find it anywhere, I eventually took it to the dealer, and they can hook it up and tell you what it is, I knew someone who worked their so it was free, but I think they usually charge 75.00
hope this helps
hope this helps
+1 Took my 03 LS to the local dealership, know a lot of the people that work there, and they pulled the code for free.
