jmcgregor30
Hey Guys,
First time poster. I've gone through and read all of the Alternator install issue posts but I'm having a little bit different issue.
I've got the belt off, cars jacked up and everything is moved out of the way per the instructions. I've got the nut off of the top bolt but I can't quite figure out how to remove that bolt and I can't see it. But the main issue I'm having is the lower bolt is out but it's jammed up on the top of the sway bar and I can't for the life of me pry it loose.
Any help would be greatly appreciated. I do all of my own work and I've never ran into an issue that's kicked my butt like this one, I just spent 5 hours working on this and most of it was spent trying to pry the lower bolt loose.
