2002 lse v8 advancetrac light blinks all the time and no cruise periodically
dannoltie
Chatham Ontario
hey guys i have an 02 lse v8 with 140000 km and im having an issue with the advancetrac light blinking all the time and the cruise control will cut out here and there... just looking for some suggestions to get this issue fixed and finally have a dash free of trouble code lights
thanks Dan
AdvanceTrac:
Same as all the other threads on this. If the ABS light is not on, then it's either the YAW sensor, the steering wheel angle sensor, or a module calibration issue. Need to get the codes to find out which. Most generic scanners won't pick up AdvanceTrac codes.
Cruise control:
Could be a failing clockspring, or since you have a gen I, it could be the throttle cable, the cruise module, or wiring. There may be a stored code to point in the right direction. Again, many generic scanners won't be able to pick these up.
AdvanceTrac:
Cruise control:
okay thanks for the reply i dont have a scanner that will read it so ill have to take it in i guess.... so youre saying these are unrelatd issues.... i had it into the dealership last year had a new steering rack 4 new injectors and an intake manifold gasket put in and after it left it began constantly flashing(when i first bought it i would get an advancetrac error periodically but it wouldnt consistently blink until it left the dealer) and the cruise control started to periodically stop working at the same time
