I am having a problem with my ls. I decided to replace the bad pcv valve on the lincoln. I have done the valve cover gaskets in the past and had no problems. After replacing the pcv valve and reassembling everything car won't start. I checked at the connections at first and could not find any problems. I decided the COP might be bad. I ordered and replaced all 6 on the 2002 3.0 v6. The car cranks and almost catches but will not run. Battery is fully charged and the car ran great before it wouldn't start in my garage. The PATS is not the problem to my knowledge the red light on dash turns on and then turns off. I don't have a code reader. I have used this sites wealth of knowledge in the past but i can't seam to figure out whats wrong with my car. If anyone has had this problem in the past your help will be appreciated. I am going to be putting on new upper and lower intake gaskets tonight. I am thinking a vacuum leak but i thought the gaskets were reusable. I feel it is something electrical and i hope its not the pcm.
