easycous723
I have a 2002 lincoln ls 3.9L can someone tell what are some signs when your heater core has went bad.
I started the car up today and there was water leaking under the car,I had remove the upper intake manifold and everything fine the leak isn't coming from the engine or the radiator, The leak looks like it's coming from the firewall on the passenger side under the car beside the transmission. I've always seen cars with heater core problems have antifreeze leaking in the floor on the passenger side from the inside of the car and I've check the 3 heater core hoses and they look fine.
Any advice on this matter will be very appreciated
