2001 TC blower motor
97ltc
nuevo
Fan wouldn't come on the other day. Checked fuses, they are good, and so is the motor. What else to look for?
thanks guys
Yes, I heard that becomes loose, I will have to check that out. Thank you!
Jump some wires to the blower motor (disconnect harness) and see if it spins.
If it does, the issue is likely the blower motor speed controller, and/or it's wiring.
You can also try putting the fan on full high, then tapping the up button again. It will click on the high speed relay in the BMSC to bypass the transistor. if the fan comes on, it's fine and the issue is still the BMSC (but wiring is probably ok)
