Replace fuel filter
Check voltage going to fuel pump
Remove injectors and send them out for flow testing and cleaning. I use RC Injectors
Pull valve covers and make sure that the exhaust cam hasn't skipped a tooth or two.
Neither of those indicate lean mixture. You have a clear misfire on cylinder 1. You very probably have marginal misfires on most of the rest of them. This has caused problems for your catalytic converters (the other code).
You need to replace all of you coils and all of your spark plugs. There are many posts on this board about it.
