I just replaced my airbag light yesterday on my 2002 LS. It is the Grey Socket bulb. Avaialble pretty cheap from rockauto.com, part: DORMAN 639048.
This was a pretty involved job, but I replaced both the clock spring and the light in the instrument panel in about 2 hours. Just a pointer: to get the instrument panel out you will need to tilt your wheel all the way down and extend it all the way out (toward you) before disconnecting the negative battery cable. You will also have to loosen the 4 nuts holding the column up, but don't remove them, just unscrew them far enough to drop the steering column a little. When you get the instrument panel out, you will have to use a Torx bit to remove the white back plate, then the same bit to remove the top circuit board. The airbag indicator lamp will just twist to unlock and pull out.
This solved the incessant chiming I had going on in my LS. Good luck!
