2001 Lincoln ls 3.9 crank no start when hot help!
jtstein98
illinois
01 LS 3.9l NEW crank no start issue
Well, I fixed the previous long crank to start issue (ended up being a brand new bad injector replaced that car has been running flawless fires right up runs smooth been driving for a week or so drove to work yesterday (15 minute drive) shut it off went in for 15 minutes came back out to move and car just cranked verified fuel at the rail but would not start as if it had no spark. Let it sit came back out a few hours later fired right up drove home fine. Tested again today short drive shut it off no restart till it cools off? Right away I figured crank sensor but I hooked up forscan while it’s in the crank no start issue and it jumps up to about 154rpm and holds steady while cranking.. could it still be a faulty crank sensor? Any way to test cam sensor? Also where are the cam sensors located! I can’t seem to find them anywhere!
