2000Conti clunking noise from passenger rear
poppers
Manchester
Hi I asked this question once before back last summer never got a solution to my problem. The noise comes from the pass side rear at least sounds like it. I changed the sway bar link on that side I've had the car on the lift about 10 times but can't seem to find anything loose or hitting shocks seem fine. Back in the late 90's there was a bulletin for garages to take care of the clunking noise in the rear they had at that time. I can't seem to get an answer from any lincoln dealer on it to what the problem was. Any ideas on what the solution was????
Thanks
Have you checked the exhaust system, maybe it's loose and bouncing up and hitting something underneath. Good luck.
When my car was finally up on the lift I was able to see the clunking noise in my 2002. Passenger side rear there is a joint that appears to be connected, but when it was looked at closer it was revealed that the joint was actually not together. I wish I could tell you more.
