im fairly new to the fourm and have been doing alot of reading on the LS' ive recently run into the problem with the battery light on and message center "check charging system" i have replaced the battery because it was original and didnt pass the load test ....with a volt meter hooked up the battery is getting 15.5 volts at idle does anyone have an idea of what might be causeing this i did do a load test on the alternator with the car running and its putting out 90 amps at idle
any idea
thanks JUSTIN
any idea
thanks JUSTIN
