chanceone559
COULD A CAR PERFORM LIKE A CHAMP BUT STILL BE A CHIT BOX?...Is there any chance the engine is garbage like the dealer made my grandmother assume?
No Smoke, No Lack Of Power, No Leaks, Plugs Look A Little White But Clean,
However,
Intake Is Filthy (Throat Of Intake), Fuel Filter Might Have Never Been Changed, Has A Clunk Clunk Clunk....quiet.......Clunk Clunk Clunk.......quiet.....Clunk Clunk Clunk....... Sounds to be coming off the side I changed the coil,
Could I have Missed The Plug Connector (Top Of Plugs) & the coil is arcing inside the chamber? Can I use A Plug Checker (Plug onto the the plug & insert it into the coil< Has a clear window to see spark>) without damaging anything? Or is there a level where I could measure the voltage of the plug going into the coil with a meter?
I had a problem with the misfiring on another car & had to unplug the battery For quite some time then run it @ a certain rmp for 2 minutes then drove for XXX amount of miles to setup the computer then unplug the ckps and run the car for a bit then plug it in & the car rearranges the data & order.... Any chance & could do the same to setup the firing order?
I do not know much of the DEW98 just that it has done well in other Situations & In The 05 mustang Ford had "Fixed" the common issues associated with this engine
Thanx In Advance
