Lincolnls800
Hi there new to lvc. I need help with my fog lights as they aren’t working at all. So far I have checked the bulbs they are good. I used a multimeter to check voltage and resistance at the fuse,relay, and pigtails. The fuse is good. There is not any voltage at all to the fuse or the relay. The other relays have voltage to them. The pig tails have no voltage Or resistance but when I turn the fog lights switch on they start getting a resistance but no voltage which really stumps me as the relay has no power to it and neither does the fuse. The little green led on the headlight switch illuminates but the cluster doesn’t show the fog light symbol I guess it’s suppose to. All other lights work including the dims and brights. I do suspect the clock spring is bad on the vehicle as the horn and cruise control don’t work and only the mute button on the steering wheel works and all fuses are good for the horn and cruise. Could the two be related? I have never seen the fog lights work the entire two years I’ve owned the car. Thanks in advance
