Justin00LS
Today on the highway I gave it about 40% gas to downshift to 4th to pass a car and the RPMs bounced around 4500RPM and the car did not accelerate. The E "error" came on the display along with check transmission. I immediately pulled over and used the XCAL2 to pull the codes. I got P0734 and P0745.
The car now acts like it is in neutral in D5, D4, and reverse and barely moves. I managed to push the car to get it rolling and then got it to a safe spot off the road by using SST, which works, but has extremely harsh shifting, if it decides to shift. Every gear still somewhat works with the SST but I don't get anywhere in reverse/D4/D5.
I ended up towing the car back home.
My car has the 3.9L with 120K miles on it and has always shifted smooth and felt great. I believe it is just the pressure control solenoid that is bad based on how it acts, but I would like to be sure before I tear the transmission apart. Should I risk replacing this soleonoid or should I just seek out another transmission?
Has anyone replaced the PCS solenoid themselves? Can the engine/transmission be dropped down and the solenoid replaced without removing the transmission from the car?
