For Sale 2000 LS Sport V8 Tampa, FL
izzy
Tampa
**********FOR SALE**********
2000 V8 Sport 98K miles Black with light graphite interior (06/21/00 build date)
Anything with an asterisk (*) below means it is already installed on the car
HID Housings (will need bulbs, G2 header and G2 pigtails)
Black eyelids
G1 LSE Front Bumper *
G1 LSE side skirts
G1 LSE Rear valance
G1 LSE Grille *
G1 LSE rear surround (backup camera installed, not hooked up, 5 pin relay and extra camera) *
G1 headlights with clear turn lenses *
G1 headlight lenses, housings and chrome bowls taken apart
G2 LSE spoiler *
Clear sidemarkers *
Roof spoiler (Spoiler King large version)
Mclaren Grille (needs repaint) all tabs in tact
Original grille all tabs in tact
Original rear surround
Original Sport front Bumper w/fogs and side-markers
Original cd/tape deck radio
Folding mirrors with puddle lights
Painted emblems black background red stars *
Driver side front door handle
Passenger side door handle front or rear
Passenger side windshield cowl
Smooth front fender moldings (ones without the LS lettering)
01 center console (no ninja cup holders) *
Extra console lid light graphite
G1 Inner right two tone tail (never found the other inner)
G1 Outer left two tone tail (inner mount is broken but repairable. Never found the other outer)
K&N filter with adapter, heat shield, aluminum intake tube *
Original intake tube and air filter box
Aluminum thermostat housing *
K&N fuel filter
Dashcam hard wired *
Eonon D2105 touchscreen head unit (steering wheel controls are hooked up)
1000 watt amp 2-12s in box (1600 watts each) *
I'm sure there are a couple other things I'm forgetting too.
Needs:
Front passenger knuckle (lower ball joint) which I already have
Drivers side outer tie rod
Sway bar bushings
Airbag light is on due to yellow wire under driver seat.
Recently done:
Front full ceramic pads and calipers
Rear full ceramic pads, calipers and rotors
Power steering pressure switch
Alternator and battery (vented correctly)
Fan pump actuator
OEM degas bottle
Windshield
Both air and heat work
Paint is 6/10 planned on doing it never got around to it
I would sell the car for $2500 by itself. There is about $2000 or more in extra parts (listed above) going with the car. Will not separate them or part them out. Asking $3800 for car and everything listed. If you're out of state you would have to travel or arrange for shipping.
