2000 LS Front Door Panel
xarruda89x
Massachusetts
Ok guys, I searched and all the pictures on here are the Gen II door panels, anyone got a picture of the first Gen ? Gonna do some speaker work.
Front and Rear
Thanks in advance
It's really simple. I believe the door setups are the same, because I did not know until now that all the pictures were Gen II doors and I just took off both of my fronts.
Anyways, three screws on bottom, one behind black plastic around handle, one on the part of the door that touches the B-pillar, and two in the handle pull on the door under a little flip cover. Then start popping it off around the edges.
use a flat head screwdriver... gently. It pops off very easily
The screw is under that black piece, the piece itself is just clipped in
The black plastic comes off easily. Use a flat head on the side closest to the engine. It will come out.
