2000 Lincoln LS V8 Slow Battery Drain.....and I have used the Search Function!
Gotcha. Thanks. I suspect you are the Lincoln LS GURU!!!!!
I will relay this info to them. How long does this take? It seems like an hour is pretty standard for these things.
Well under an hour, but their minimum charge is probably an hour. Of course, I would argue that this should be a freebie since it was their mistake that caused it.
UPDATE
The blinking light is fixed. They had to reprogram the Steering Wheel Angle Sensor. (free of charge) Joegr, Thanks again for your help.
BTW, I've been reading many different posts about the CAI and the heat soak problem/lack of Heat Shield. Has anyone come up with a solution? Did the "ram air" plumbers tubing work? Thanks to anyone who can help.
Hello, my name is Juan and I have a 2000 Lincoln LS. My battery is draining in an amount of 30 hours as well. Was wondering if you could give me any advice to eliminate the extra hassle. I really need the help because as you know this issue is a headache.. Thanks alot!
