I'm looking on Terry's Jaguar parts for the bearings (some members here have recommended that site for parts) because I absolutely cannot find them anywhere else on the web. I've read some posts claiming the S-Type 4.0L is practically the same engine as the 3.9L, and that's pretty much what I'm going on here. My question is, does the LS 3.9 have oil holes on the crank journals? I haven't accessed the bottom of the block yet, will do that soon, but I'm about to order them from Terry's Jaguar and the rod bearings available have no oil holes on them.
My engine has intermittent rod knock on idle and definitely knocks as I back off the gas. The thing's been sitting for two years before I bought it in cranks-but-no-start condition, fixed that with timing set replacement and fuel pump replacement. As soon as it started up there came the knocking. Obviously I need to get in there before I know how bad the situation is, but my main question is about the bearings.
Also, the interesting thing is that the 3.0L bearings are all over the internet but the 3.9L ones aren't, while the 3.9 timing set is all over the internet but the 3.0 is nowhere to be found (I have a 3.0 as well).
