2000 Continental door panel removal
Michael
111111 Los Feliz Ave
Does anybody know how to remove a front door interior panel ?. I have removed the 5 crews (two in the door handle, two at the bottom under the map pocket, and one on the side) but I still cannot remove it. Are there push pins to be removed ?. I will appreciate any hints.
Try pulling up very hard first. Sometimes its plastic pins, sometimes its hooks and it hangs on the door.
Lift it a little to disengage it at the window sill, and then pull away very hard. There are several push pins holding it in place after you remove the screws. They are very strong, they won't brake. Start pulling at the bottom. You may want to use a tool to locate the pins at the bottom and pry them.
