murphymusic
Firstly,thank you all so much for guiding me through years of successful troubleshooting and repair of my Wife's 2006 Lincoln LS. I have been on this forum for weeks trying to get the cooling system/AC system to operate correctly and I am at my wits end.
Years ago, the LS started blowing hot air out of the passenger side vents. I researched the problem on this forum and replaced the DCCV (although cuz' I'm a cheapskate I got a used one off of Ebay). The problem was fixed...for a while (maybe a year or so) and the uneven cooling/heat slowly returned.
Fast forward to this summer: The LS's radiator fan was constantly going full-blast. It sounded like the car was about to explode. My wife suffered an overheat while out of town and I decided it was time to get to the bottom of these issues. Again, I returned to this forum and after searching many threads with similar symptoms I ordered a new thermostat, thermostat housing and water distributor assembly through RockAuto
ORMAN 902903 {#3W4Z8548AD}
I thought it would also be the perfect time to order a new DCCV :MOTORCRAFT YG378 {#2R8H18495AB, 2R8Z18495AA}
After removing the old t-stat housing and water distributor assembly I discovered that the water inlet tube was completely crumbling apart so, I ordered one and when it arrived began the repair.
After everything was buttoned up I filled the system w/appropriate coolant and bled and bled and bled it. I followed the Ford shop manual fill and bleed instructions to a tee.
The Coolant leak and racing fan issues were resolved, but the A/C still blew hot on the passenger side! Again, I returned to this forum and learned about the DATC self-diagnosis. The DATC returned these codes: 2799, 1262. I followed the pinpoint test J and all tests pointed to a defective DCCV. I contacted RockAuto, set up a return and ordered a new DCCV (same part and manufacturer). It arrived yesterday. I put in the new DCCV and HALLELUJAH I had cold air from all vents!!! I ran the self-diagnosis after the repair and came up with only code 1262 (not surprising because I never touched the defrost actuator).
I thought that I had this thing licked!!
I was wrong!
Later that evening, I wanted to take the LS for a spin and enjoy the cold A/C...guess what....HOT on the passenger side and luke-warm-coolish on the driver's side!! I once again ran the self-diagnosis: 2799, 1262....crap!!!
What are the chances of getting 2 OEM DCCVs that are defective??
I've not yet done the pinpoint test J on the new DCCV.
I have not replaced the Degas bottle (haven't lost coolant and don't see a leak).
Could this 1262 code be the culprit? I've researched how to remove the instrument cluster to gain access but I'd rather not if it's not going to help with my issue.
Many thanks to any of you that might be able to shed some light on this for me!
I was wrong!
