AmsterDutch
Hey Guys I was wondering if anyone could do me a solid and help me with some readings off there Forscan in the Live feed Dashboard?
Wondering if someone can hook up there Forscan and turn on the AC (Air Conditioner) go into Live Feed and select all three of these PIDs in Module PCM for FANVAR_F-Cooling fan driver fault....FANDC-Variable Fan Duty Cycle....FANVAR-This parameter indicates the engine cooling
I want some numbers if you could be so kind ...while looking at FANDC I want to know what the % changes to when you hit the AC button and turn it on ...Wondering if it goes to 12 Volts as soon as you turn on your AC and if the FANVAR % goes up because mine is staying on 9.68% all the time no matter if AC is on or off...I changed out the actuator and tested both the used one I bought off of Ebay and the exsisting actuator I had in the car ...when applying 12 Volts to the actuator I heard both of them click and both of them rattle a bit when shaken ...so i'm thinking there not stuck ...any help would be great ...also is it possible that the fan blade can become loose from the fan housing assembly ....feels and looks like there is a bit of play in the fan blade? Thanks
