Drumlove521
What's up my beautiful people, does anyone know exactly how to replace the transmission fluid filler tube o ring? I've tried searching for a write up on it, but to no avail.
I had the transmission fluid/filter changed a few days ago, the mechanic told me he'd either have to drop the exhaust or loosen a motor mount to get to said bolt. She's still leaking fluid so I'm going to try and get this handled today.Generally, you need to drain out the trans oil by dropping the pan or get a suction device and suck it out threw the dip stick tube. Once you get that done, there's a bolt bracket off the tube that bolts the tube to the bell housing. Once you get that bolt out, wiggle the tube free from the engine bay. Good time to do a filter if you have the pan down.
Right on, just wanted a second opinion on the matter. Thank you sir.I've never had a main seal leak, but if I knew one was leaking I would absolutely do both now instead of having to repeat the process later. Good luck.
Dude, this is badass. Asking him if he'd be down to do it. Thank you sir.If hes dropping the Trans, copy the spec work sheet I posted in the J-mod article and see if he will drill out the valve body ports as described in the article. The stock porting absolutly sucks. The stock porting makes the torque converter do long sloppy gear changes from 1st to second and also to 3rd. The Jmod will make clean fast shifts threw the gears that throws you back into the seat each time with a spirited throttle but dosent have to be WOT. It was one of the most satisfying mods I'v done. As was predicted by the J-mod guys. You wont regret it. Also it keeps your trans oil cooler by not making the TC stay out of lock up so long between shifts. Win, Win....
At the end of this article, I added the spec sheet for any trans guy to follow
LINCOLN MARK VIII 4R70W TRANSMISSION 1-2 SHIFT ACCUMULATOR REPLACEMENT - JMOD
Submitted by BlackiceLSC Visit the Lincoln Mark VIII Forum for more info The following is a “How To” of how to perform a 1-2 shift accumulator piston and spring assembly replacement and 2-3 shift accumulator assembly replacement as well as the...www.lincolnvscadillac.com
