rmorrow1970
1998 lincoln continental.  air ride rear suspension.  stock everything.  never messed with.  never any engine warnings.  when you park the car........SOMETIMES the rear will lower to the ground (or as close as can) within fifteen minutes, sometimes it may take two days, sometimes it does not do it at all, and remains at the correct height.  If you start the car, it will pump up instantly, and run and ride correctly until shut off and parked again.  both sides lower.  as it does it only occasionally, im lost as to why.  or why sometimes it takes six hours to lower, other times fifteen minutes.  the most typical time frame is within an hour it lowers itself, but today, it did not lower itself at all.  it is parked on a slight incline, and backing the car in does not seem to matter.  i ran the car and got it lifted, and now have shut off the system via the trunk switch.  it has been two hours, and it has not moved....but as sometimes it does not...im not sure that this means a darn thing! any suggestions?? i love my baby!! thanks
rick
			rick
