nel606
Hello Everyone,
It started after I put new ends on the wires connected to the brake light switch. I have no idea if that has anything to do with it. The brake lights and shifter lock work fine now, but even though it says ready when I press the on button, my cruise control wont engage. I have checked fuse 32 and it seems fine. I've also checked the connector to the cruise control switch on the brake pedal and I didn't see anything wrong. Should I replace the switch on the brake pedal? Is there speed control module or something like that I should check? Any ideas where I should go from here?
Thank you
Thank you
