1960-66ish Continental Motor Swaps?
Stack
Mad-Town
What other BBF's can you put in those bad boys to replace either the 430 in the earlier models or the 462's in the later models???
Help me out guys!
No I dont THINK so....
Check out my post just before yours. Maybe alot of lurkers here but no one with any info.
Let me do some checking around for you on that swap though.
I want to say the 390 or a 428. I'm not sure if a 429 will work but I think they had similar setups.
any FE engine will work if you need a block let me know. Have a 62 390 solid lifter block.All machine work has been done.
possible engine swaps, early- to mid-60s Lincolns
Firstly, I simply must ask the question, "why?". Is the engine that's
currently in the car worn out or close to it? Is there anything wrong with
the engine as an engine? If not, I see no reason to make a switch . . .
. . and I can see lots of reasons NOT to switch engines, unles you're a
"glutton for punishment". Seriously. I'm not trying to insult you or
question your judgment. I just want to know the real "why".
Secondly, any of the suggested possible engine swaps/changes are going
to prove to be a disappointment, even in the best of luck and circumstances.
This is because these Lincolns are exceptionally heavy. Thus, they require
MASSIVE amounts of torque---torque that you will not get from any other
engine in sufficient quantity, unless you opt for a late 60s - early 70s 460.
Now, the 460 is physically much smaller on the outside. It IS, to be very
sure, eminently strong enough, "torquey enough", for the job.
But, again; I have to ask, why do you want to do this job? Unless the
engine in your car is seriously "tired", I advise against it. While the
Lincoln engineers did, at times, design weird stuff like hydraulic windshield
wipers or four-muffler dual exhaust systems [translated, quiet but
expensive], these engineers DID know what they were doing when it came
to engines. You can be very sure about that.
Finally, what do you think a different engine will achieve for your car?
Jerry
