The search is over I've been searching and working...... 98 LSC 123k on body
around 80k on engine.
So far I replaced battery, alternator.....Went to Advance Auto parts and Salvo auto parts n got both tested. They tested out good. Battery is Autozone---- Alt. is Salvo's .OE rebuilt 3yr warranty.
While car sat for a few hours the battery was at 12.76.
Under load with high beams, radio, heat, and windshield wipers on the battery was at 11.80. With car running and nothing else on it went up to 12.5.
I did discover a wire coming from alt wire tucked under coolant reservoir but I grounded it. Got damn shop who installed the engine. Never again
Should I take it for a ride to give alt. time to recharge the battery?
Next
The car drives a little rough I changed coils, plugs, k&n filter, changed the IAC.... Pulled codes 1518 for stuck open imrc and second code for o2 sensor lean bank 1 or 2. I believe the problem with the o2 sensor code is because I haven't tightened the exhaust after I installed the trans.
For the p1518 I've read of some using Seafoam. I have some but haven't used it until I tighten the exhaust.
Next
