dndisturb
Hello all,
Been DDing an 06 LS V8 for the past 10+ years without much issues (other than the usual cooling system parts, trans solenoid, etc.)
Looks like my driver-side / LH rear door actuator failed (manual lock lever stuck in the UNLOCKED position, door still opens/closes normally either using the exterior door handle or the interior lever).
Not going to bandaid fix it, and just go a "new" latch assembly. Would anyone (perhaps master @joegr
) know the part #?
Found a bunch of threads here on LVC for Gen1s, but none for Gen2s.
Apparently the part # for Gen2 is 3W4Z-54203A29-BB.
Is this interchangeable with Gen1's 2W4Z-54203A29-AB or 2W4Z-54203A29-EA?
The 06 LS Workshop Manual only lists "54203A29" as the part # for LH rear :
2006 Lincoln LS Workshop Manual
Many thanks in advance!
