05 V6 Sst
LEOV5
So Cal
Well it is all done in my 05 V-6 LS. We (Mike, Brian and Tony) installed a SST shifter in my LS. When you shift to SST mode it shows up on the display on the dash with SST and gear you in. It worked grweat all weekend and today. I oove this set-up and recommend it to all you V-6 owners to change if you like to have control of your shifting. It took about an hour to install and everthing just unbolts and bolts back up. There is a litter metal clip on the passenger side front of the shifter base that will need to be unclipped before the old shifter will come out. But other than that it was pretty easy. I know Tony and Mike where doing all the hard work. But hey than you guys very much!!!!!!!
Glad to do it for ya Brother!
Nothing broke and no one got hurt! :D
See you again at FFF in April, if not sooner.
Yeah!!! Espeically after they asked you to go under the car.
