Joseph Wood
Yesterday my '05 Lincoln LS V6 was idling fine at a stop light, then went down from 1100 rpm idle to 400-500 -- very rough. When I tried to give it gas, it died or the rpms went down to 100-200 (had to restart it several times). Over the next couple hours, it wouldn't start up or would start up and quickly die.
I had it towed and after it towed, it started and drove about 100 feet without any problems. Then it wouldn't start again. My mechanic started it up and tested it and found it had 5 PSI on the fuel line, so he replaced the main fuel pump.
But, that didn't solve the problem. There is still only 5 PSI at the fuel rail, and a half a tank of gas. I was thinking the fuel sender might be bad, low fuel levels, bad fuel pressure sensor or bad connection at the pressure sensor or regulator? Any ideas? Right now it won't start. If I tow it, it will start and run for around 50 feet or so (maybe tilting the tank does something?).
Thanks you guys.
Thanks you guys.
