05 LS Brake Indicator Light
casecito
Detroit
I started having an intermittent problem with my 2005 LS. The park brake indicator light on the cluster will occassionally pop on while I'm driving. When this happens the power steering also stops working. If I stop and start the car again the issue goes away. It has happend probably 4 or 5 times in the last 2 weeks. Any ideas on what it could be??? Also my ABS light and tracktion control indicators on the cluster have been on for about the last 2 months, just thought I'd throw that in just in case the 2 issues could be related. Hoping to get a little info on the issue before I would visit a dealer and let them tell me it needs mega bucks in repairs. The car only has about 55,000 miles on it, but it was in a front end collision at about 30,000 miles on the front right corner.
Well, I certainly don't understand any link between the low brake fluid light and the power steering. Have you checked the brake fluid level? If you're not certain that it's full, then add some.
Yeah I already checked the brake fluid level...no issue there. I agree that the power steering issue being connected seems odd. Definetly points more towards an electrical issue!
From the service manual...
The variable assist power steering (VAPS) system controls the level of power assistance available to the driver based on vehicle speed. At less than 3.2 km/h (2 mph), full power steering assist is provided to decrease steering efforts and increase maneuverability. Between 3.2 km/h (2 mph) and 191 km/h (119 mph), steering assist decreases gradually at a calibrated rate to raise steering efforts for increased directional stability and greater road feel. At greater than 191 km/h (119 mph), steering assist is constant.
The front electronic module (FEM) outputs a pulse-width-modulated (PWM) current to the control valve actuator. The control valve actuator controls the hydraulic valve that determines the amount of hydraulic assist provided to the steering gear. The amount of assistance provided varies with the control valve actuator current, which is based on vehicle speed according to a look-up table internal to the FEM. The FEM pulse-width modulates the control valve actuator current to provide the desired amount of assistance. The amount of hydraulic steering assistance provided by the VAPS subsystem is proportional to the average control valve current.
The vehicle speed is provided to the FEM through the standard corporate protocol (SCP) network from the anti-lock brake system (ABS).
The engine rpm is provided to the FEM through the SCP network from the powertrain control module (PCM). The FEM uses the engine rpm to determine if the engine is running. The FEM only outputs control valve actuator current when the engine is running to minimize noise, vibration or harshness when the engine is off. The FEM assumes the engine is running only if the engine rpm is greater than 100 rpm.
Upon starting the engine, the FEM provides a 200 millisecond full-ON pulse followed by a 150 millisecond full-OFF pulse to the control valve actuator. Normal VAPS system operation begins after this cleaning stroke is complete. In the event the rpm signal is invalid from the PCM (less than 100 rpm) and the vehicle speed is less than 1.6 km/h (1 mph), the VAPS system does not carry out the cleaning stroke or apply current to the control valve actuator. When the engine speed exceeds 100 rpm, the system carries out the cleaning stroke and begins applying the calibrated current to the actuator.
It seems like the ABS module might be the common link here. I think it's time for you to get the system scanned (Ford specific scan tool required) to see what the diagnostic codes for the ABS system are and then go about fixing it.
