they are 2 amps, the rear deck one is a 100 watt (50watt per channel) 2ohms amp and that only powers the sub, on the left hand side of your trunk if you remove the covering there is where you will find the other amp this is 4 channel amp 200 watts (50 whatts per channel) running at 4ohms.
all the crossover is being done at the head unit and you just cant replace the amps the HU wont allow it to go higher valume what you have to do is keep factory amp and use the HIGH outputs (that goes to your speakers) and plug that into the new amp HIGH inputs and if your new amp does not have HIGH inputs then you need a converter to turn that into LOW. but really the THX sounds amazing why would you want to mess with the clarity of that system.
