03 Aviator seat probs
Modelafish
Sparks
My wifes Aviator has a few problems with the seats. Big thing right now is that it is stuck in the back position, and since she's short, it's a real problem. The seat will move maybe a quarter of an inch either way. I can see the screw drive rotate a little bit, but very little movement. I've seen a TSB for the Navigators for this problem, but not the Aviators. Can't find anything jammed in the track. Prior to this, she was having problems with the drivers seat not staying in the "saved" position (more than just moving back when you turned off the key). And the heated seat doesn't work. I've read about the filter on this system, but where is a diagram showing where it is and how its hooked up. I wanted to remove the driver seat to check it out, and removed the two front bolts, but having a hard time accessing the rear bolts. Again, diagrams would go a long way.
