TooManyToys
Hey guys. I haven't been around much. 30k ago at 100k I replaced all the coolant parts except radiator, doc'd in an old thread. Yes, Motorcraft parts all the way including degas as a PM.
This spring the LS has gotten cranky. We had an overheat, which shouldn't have happened. After checking things out I found the electric cooling fan had failed by pulling the control connector and the fan stayed static. Main power was good. A salvage fan plugged in and immediately went to full speed. Forscan shows the PCM is pulsing, but not controlling. Second fan does the same. I still need to sort out if the harness has shorted to ground or if the PCM has an issue. Anyone who has gone this path who has suggestions please jump in.
But my wife had another high temp event despite all the air bled out a good while ago and max cooling fan speed. Checked it at home and coolant was down. Refill and rebleed completed. But as I'm checking all over I found white residue at the passenger headlight. Looking around there is a fissure in the radiator opposite side of top hose, so the age and probably the overheat took its toll.
The disparity in price between the Motorcraft radiator and aftermarket RockAuto wares is high. While I usually always go for M/C as it will comparative to OE in capacity, I was wondering if anyone had success with any of the aftermarkets with this marginized cooling system?
