03-04 cobra exhuast manis
bryantaylor
jacksonville, fl
i have read threads saying they flow better and bolt right on, need a new steering joint and so on. but does anyone have actual pics of the manis installed? a friend will sell me the stock manis from his 03 and i am thinking about doing the swap.
Never installed them, put em in place and then started on the project and then quit, so they sit on the wall.
Well I have 04 manifolds, but I need them with my engine. Others have installed them though and it helped it seems. The cars breathe fine, its the exhaust thats a little restrictive. Cobra manifolds with 2.5" pipe would be ideal.
I am not sure about the 01s. I think those of us who switched went 03/04 but I am sure if there is a design difference.
Unless you are doing A LOT to the intake, headers are really not needed.
Then the 01s must be a different design. The 03/04s have to have modification of the steering shaft.
You'll have problems with the EGR as the tube will need to be modified significantly. also you'll need a new Cat setup also.
EGR, Cat? Not me! lol
But he is right.
No I dont have pics, the only pics I have are with it having Aviator manifolds.
So all you have to do is install them (the 01s) and make a spot for the egr, and install new cats and exhaust?
